Standard Poodle Club Forum
Standard Poodle
Construction waste shredders have the following features
Post new topic   Reply to topic    Standard Poodle Club Forum Forum Index -> Announcements
PostPosted: Thu Feb 22, 2018 6:32 am    Post subject: Construction waste shredders have the following features Reply with quote
SBM Machinery Factory production of building waste shredders has the following characteristics:
First, the double rotor smashed up and down
The two sets of rotors in series with each other make the crushed material produced by the upper rotor crushed again by the hammer of the lower rotor which is rapidly rotating. The inner materials collide rapidly with each other and smash each other to achieve the effect of hammer powder and powder material , Unloaded directly.
Second, the hydraulic starter casing
Hydraulic hoist device, only one person can easily hoist case, not only lightweight and fast and safe, easy to maintain.
The machine is designed without mesh grate at the end of the material moisture content is not strictly required, there is no paste blocking sieve problem, but there is no fine powder can not be discharged in time, the problem of repeated crushing, so crushing efficiency, there is no hammer Invalid wear phenomenon.
Third, there is no mesh grate at the end, high-humidity materials, not blocked
The traditional grinder with grate plate does not adapt to raw materials with moisture content higher than 8%. When the raw material moisture content is higher than 10%, it is extremely easy to cause serious blockage, the hammer can not be rotated, the material can not be discharged, or even burn Bad motor, seriously affecting the production.
Fourth, a unique two-way gap technology
After the hammerhead wear and liner between the larger gap becomes coarse, can be moved out of the center of the hammer position reduction and the gap between the liner to continue to use. You can also adjust the gap from the outside to the liner to control the particle size. A hammer can be used top three hammer.
The pollution of construction waste in life is very harmful to our health, so SBM Heavy Industries has designed a variety of construction waste crusher. With the development of urban construction, more and more buildings to be demolished, followed by a large amount of construction waste, how to deal with construction waste has become a piece of municipal construction in front of a problem. Renewable resources in construction waste, including mainly muck, waste brick, waste concrete, waste wood, scrap steel, scrap metal components. Construction waste shredder equipment can turn these things into rubbish.
View user's profile Send private message
Post new topic   Reply to topic    Standard Poodle Club Forum Forum Index -> Announcements All times are GMT
