Standard Poodle Club Forum
Standard Poodle
Gold ore crusher protection points with discrete
Post new topic   Reply to topic    Standard Poodle Club Forum Forum Index -> Announcements
crushermachine169
PostPosted: Fri Feb 23, 2018 3:50 am    Post subject: Gold ore crusher protection points with discrete Reply with quote
With the continuous development of production and technology, especially the extensive use of motor as the driving force of gold ore crusher, which is to create the conditions for the electronic crusher safeties, when the crusher serious overloading, the motor has excessive current, An overcurrent signal is sent from the sensor sample to the signal analysis and comparison device, which gives instructions to protect the crusher.
gold ore crusher occurs under normal load thrust plate break, but fell into the crusher non-broken objects or a serious overloading machine, or even stand cracking. In order to overcome the shortcomings of the mechanical safety device, a hydraulic shank gold ore crusher has emerged. The gold ore crusher is characterized by a hydraulic connecting rod device, that is, power transmission, when the crusher falls into non-broken objects or the machine is seriously overloaded When the hydraulic system will increase the hydraulic pressure, if the combination valve to the high pressure relief valve setting pressure, the high pressure relief valve overflow, the connecting rod cylinder and the piston, the motion stops to swing, so that Play insurance role.
gold ore crusher equipment Mechanical safety device As a gold ore crusher safety device, the thrust plate has the advantages of simple structure and low cost and is suitable for any type of driving mode. However, the device is disposable and must be replaced in case of damage. The operation is quite difficult, time-consuming and labor-intensive to reduce production efficiency, and the thrust plate is generally cast into line without the direct machining of the installation and use, due to casting error, technology and materials and many other factors that make the thrust plate for the insurance Protection points have a lot of dispersion.
View user's profile Send private message
Post new topic   Reply to topic    Standard Poodle Club Forum Forum Index -> Announcements All times are GMT
